查看: 95|回复: 3
Parked over the line.
 楼主| 发表于 2019-9-18 05:38:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"what is it with drivers parking 10 feet of their trailer over the line at truck stops. with the trailer tandems slid all the way up for California and the arse of it hangin over the line. if ya wanna do that crap can't ya have some considerations for the rest of us that wanna park and choose one of the many spots at the perimeter of the lot instead of hangin your trailer into the spot opposite of you . yeah i tapped your trailer. bahahahahaha. \n\nrant over ya'll.  thanks for reading. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-18 22:41:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"So you came on here and told us about it, the truth is you seen his truck parked wrong couldn’t get in the spot close to the door had to walk across the parking heavyweights so your ankles was hurting. Seen you couldn’t defend against the driver came on here and told a lie. \n\nI’m on with that it’s the internet. ","replyToPid":0}
 楼主| 发表于 2019-9-18 05:48:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"i would but the guy pulled away before i could. had to been on his 30min break","replyToPid":0}
 楼主| 发表于 2019-9-19 02:49:02 来自手机 | 显示全部楼层
792495 发表于 2019-09-18 14:41:53 So you came on here and told us about it, the truth is you seen his truck parked wrong couldn’t get in the spot close to the door had to walk across the parking heavyweights so your ankles was hurting. Seen you couldn’t defend against the driver came on here and told a lie. \n\nI’m on with that it’s the internet.
","text":"I guess your name says it all huh","replyToPid":210174}
GMT+8, 2026-2-11 07:13 , Processed in 0.078819 second(s), 24 queries .
