查看: 217|回复: 6
Hypothetical question
 楼主| 发表于 2019-9-18 03:31:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a question for anyone that can answer if I have failed a non dot drug test and it shows up on my employment history is there any transportation companies I can work for or am I done trucking?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-18 20:59:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who cares? That’s your problem! You addict! ","replyToPid":0}
发表于 2019-9-18 22:08:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Better than being addicted to being an åsshole like Swifty here","replyToPid":0}
发表于 2019-9-18 09:11:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"No you should be fine. ","replyToPid":0}
发表于 2019-9-19 00:26:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"It depends on the company's policies and their insurance company they use. But mostly insurance company that creates the problem. If they can't insure you or if it cost WAYYY to much to insure you then they won't hire you."}
发表于 2019-9-19 09:50:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"you should still be able to get hired on with a trucking company, might not be one you really want to work for but no you won't be banned from the trucking industry and depending on how long ago it happened then you might be required to go have a evaluation done first before getting hired","replyToPid":0}
发表于 2019-9-20 14:36:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"In the Green Book. If you failed  a test. You have to attend some type of drug program and be tested to show you are good to drive again.","replyToPid":0}
GMT+8, 2026-4-18 02:51 , Processed in 0.103645 second(s), 24 queries .
