查看: 483|回复: 25
Caves of Kansas
 楼主| 发表于 2019-9-17 02:22:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Holy cow. I'm the type of guy who goes out of his way to parallel park my POV.  the most exciting time of my day is docking. I was absolutely tested and thrilled today! Has anyone had the docking pleasure of the underground multiplex in Lenexa Kansas? just south of KC?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0},{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true}
发表于 2019-9-17 03:00:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"not Kansas but there is a cave in MO set up the same. whole under ground town.","replyToPid":0}
发表于 2019-9-17 02:24:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you for sharing. I would’ve thought I was in the wrong place, for sure. My first load solo is today actually and this would’ve freaked me out. Hope I get to see this in person, very cool 😎 ","replyToPid":0}
发表于 2019-9-17 02:59:45 来自手机 | 显示全部楼层
发表于 2019-9-17 03:44:16 来自手机 | 显示全部楼层
764851 发表于 2019-09-16 19:00:15 not Kansas but there is a cave in MO set up the same. whole under ground town.
","text":"Carthage MO","replyToPid":208900}
发表于 2019-9-17 03:26:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Missouri looks the same. First time was not fun at all","replyToPid":0}
 楼主| 发表于 2019-9-22 04:44:13 来自手机 | 显示全部楼层
814135 发表于 2019-09-21 01:06:25 I hope my job let me know I'm going in a cave ahead of time.
","text":"you'd think right... No mention at all.","replyToPid":211934}
 楼主| 发表于 2019-9-22 04:54:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run w a food service personally.  There were 49 businesses listed on the directory and there were 70+ dock doors. I only saw dry trailers and reefers.","replyToPid":0}
发表于 2019-9-21 20:10:47 来自手机 | 显示全部楼层
814135 发表于 2019-09-21 01:04:53 What's in the cave?  What are some of the things you delivering or pick up in there?.
","text":"it's everything from Ice Cream to frozen turkeys to chickens all kinds of different food in freezer warehouses","replyToPid":211933}
发表于 2019-9-21 20:11:26 来自手机 | 显示全部楼层
","text":"nope they usually won't let you know it's in the caves until after you get there and check in with security and they tell you which caves to go in","replyToPid":211934}
发表于 2019-9-17 03:27:43 来自手机 | 显示全部楼层
786073 发表于 2019-09-16 18:24:57 Thank you for sharing. I would’ve thought I was in the wrong place, for sure. My first load solo is today actually and this would’ve freaked me out. Hope I get to see this in person, very cool 😎
","text":"They're in MO. too!","replyToPid":208875}
发表于 2019-9-17 03:32:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Low a/c & heating cost. Maybe I'll buy one somewhere & build a house in it!? without.windows, walls, doors, heat, a/c, or insulation!? Cave man!😎","replyToPid":208922}
发表于 2019-9-17 03:34:07 来自手机 | 显示全部楼层
554946 发表于 2019-09-16 19:32:43 Low a/c & heating cost. Maybe I'll buy one somewhere & build a house in it!? without.windows, walls, doors, heat, a/c, or insulation!? Cave man!😎
","text":"Just need water & sewer","replyToPid":208924}
发表于 2019-9-17 04:39:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes","replyToPid":208940}
GMT+8, 2026-4-18 11:37 , Processed in 0.116825 second(s), 24 queries .
