查看: 167|回复: 12
Labor day vacation meditation time
 楼主| 发表于 2019-9-16 23:08:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"Had time to get this ol gal back in the air over Labor day vacation. Hope y'all had a pleasant holiday. ","videos":"[]","link":"{}","pics":"[{\"description\":\"1974  Skyhawk 172 Ii\",\"height\":640.0,\"name\":\"\",\"url\":\"\",\"width\":1131.0},{\"description\":\"11,500 msl over Hastings Nebraska\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"Aurora Nebraska\",\"height\":543.0,\"name\":\"\",\"url\":\"\",\"width\":960.0},{\"description\":\"Lovewell reservoir near Superior Nebraska\",\"height\":543.0,\"name\":\"\",\"url\":\"\",\"width\":960.0},{\"description\":\"The string of lights is I-80 between Aurora and Grand Island Nebraska\",\"height\":543.0,\"name\":\"\",\"url\":\"\",\"width\":960.0},{\"description\":\"Final approach to home base. Not the clearest pic. \",\"height\":543.0,\"name\":\"\",\"url\":\"\",\"width\":960.0}]","canComment":true}
发表于 2019-9-19 02:21:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a crush on you  drives trucks, check.  likes cats, check.  and now flies planes.","replyToPid":0}
发表于 2019-9-17 05:33:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"You pilot the plane?","replyToPid":0}
 楼主| 发表于 2019-9-17 06:26:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes. I earned my airman's certificate back in 08","replyToPid":209086}
发表于 2019-9-18 16:26:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Instrument rated or just ppl for vfr ","replyToPid":0}
 楼主| 发表于 2019-9-19 02:19:58 来自手机 | 显示全部楼层
366847 发表于 2019-09-18 08:26:54 Instrument rated or just ppl for vfr
","text":"PP ASEL VFR Complex endorsement. I'm guessing you carry an airman's certificate?","replyToPid":210002}
 楼主| 发表于 2019-9-19 02:44:41 来自手机 | 显示全部楼层
558928 发表于 2019-09-18 18:21:34 I have a crush on you  drives trucks, check.  likes cats, check.  and now flies planes.
","text":"I'm blushing lol","replyToPid":210345}
发表于 2019-9-19 05:59:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Na. Considering ATP flight school for the majors over degrees in the medical field. So VFR Complex is strictly VFR or is IMC permitted. Never herd of complex or asel. Is that replacing PPL or for power plant mechanics to test run?","replyToPid":0}
 楼主| 发表于 2019-9-19 08:11:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Asel is an acronym for \"aircraft single engine land\" meaning I'm only rated for operation of single engine fixed wing ac and landing on solid surfaces. not water. I am strictly VFR. Complex means I can operate complex system's such as retractable gear, variable speed prop, GPS, guidance systems, different types of gauges that monitor different functions of the engine and ac.","replyToPid":0}
禁止发言
发表于 2019-9-19 08:51:13 来自手机 | 显示全部楼层
GMT+8, 2026-4-18 17:10 , Processed in 0.074836 second(s), 24 queries .
