查看: 135|回复: 5
How much will blower motor cost if replacing it ? I’m curious. My A/C or heat is not blowing anything no air coming out
 楼主| 发表于 2019-9-16 22:19:37 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-9-16 22:46:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why not do it yourself? All your doing is replacing a part! Maybe you have a loose wire or a fuse? Or even the switch that turns it on or off? Poor o/o can’t work on his own equipment! That’s the difference between me at swift and you at who knows where! Quit and join our excellent work environment!","replyToPid":0}
发表于 2019-9-17 00:19:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try to reset your AC if you haven't tried it. There's videos on YouTube on how to do it.","replyToPid":0}
发表于 2019-9-16 22:33:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends on your make and model but first, you need to make sure you don't have a blown fuse","replyToPid":0}
发表于 2019-9-17 04:45:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"60$ for blower  a switch on dash around 30$ but check your fuses first . After you do get motor out you can check it on a battery one week re to ground other wire to positive just make sure before you buy one ","replyToPid":0}
发表于 2019-9-17 05:08:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"What kind of truck do you have? Some of them have a way to reset your ac/heat in a case like this","replyToPid":0}
GMT+8, 2026-4-18 04:39 , Processed in 0.094727 second(s), 24 queries .
