查看: 166|回复: 9
If you edit your logs on an ELD
 楼主| 发表于 2019-9-16 04:54:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"Are DOT officers going to see that it has been edited?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-16 18:09:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's the law, to be compliant the ELD needs to lock while driving, uneditable drive time, must switch to driving automatically, among other requirements.","replyToPid":208688}
发表于 2019-9-16 05:23:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, if they look that closely, however typically they do not. But note editing is not illegal ","replyToPid":0}
发表于 2019-9-16 13:16:28 来自手机 | 显示全部楼层
38398 发表于 2019-09-15 21:23:32 Yes, if they look that closely, however typically they do not. But note editing is not illegal
","text":"editing drive time isn't illegal but makes you non-compliant.","replyToPid":208516}
发表于 2019-9-16 14:04:08 来自手机 | 显示全部楼层
462372 发表于 2019-09-16 05:16:28 editing drive time isn't illegal but makes you non-compliant.
","text":"I agree to that.","replyToPid":208663}
发表于 2019-9-16 14:07:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"When i drove for swift I never worried about editing e logs! No forced freight!! Now I’m live life as I’m training a new breed of truckers! Day 16- and counting! ","replyToPid":0}
发表于 2019-9-16 15:19:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on your eld. My company eld let’s you edit but changes the color of the text in details part so it sticks out like a sore thumb. ","replyToPid":0}
发表于 2019-9-17 02:25:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep and they can see if the driver edited or if the office edited. If you must edit make sure you leave a good description for why you did it in the comments. Roadside inspections don’t always pull up the edits, but FMCSA company auditors will always see it and can issue citations if they suspect it was a falsification. ","replyToPid":0}
发表于 2019-9-17 02:40:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Definitely ","replyToPid":0}
发表于 2019-9-17 02:42:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"They could also see whenever you where editing paper log but couldn’t prove it.","replyToPid":0}
GMT+8, 2026-2-11 05:28 , Processed in 0.124743 second(s), 24 queries .
