查看: 204|回复: 9
What tips are you going to give someone who is just starting?
 楼主| 发表于 2019-9-15 05:07:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"Got any?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-15 21:24:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"My trainer told me years ago and it’s stuck with me since then..\nIf you can't see it, don't trust it. If it doesn't feel right, look right, or if you're not comfortable with it, don't do it. 25% of driving a truck in snow is skill. The other 75% is knowing when not to do it. And as someone else once said, \"You can go too slow as much as you want, you can only go too fast once.\"","replyToPid":0}
发表于 2019-9-15 22:39:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont give up. mistakes happen. what you do with those mistakes defines what kinda trucker you are. safety first. watch your mirrors. slow down.","replyToPid":0}
发表于 2019-9-15 10:45:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Safety before everything","replyToPid":0}
发表于 2019-9-15 11:22:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Save your monies!","replyToPid":0}
发表于 2019-9-15 10:21:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your are the boss and you choose get job done in a safely manner, communicate to your company what’s going on but don’t let them push you do do anything if it’s not safe, be professional behind the wheel what i mean by that is be responsible and courteous to others don’t tailgate, slow down or you’ll roll that truck.\n","replyToPid":0}
发表于 2019-9-15 09:22:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Find a medium size carrier those are the best ones. No major carriers your just a number to them. ","replyToPid":0}
发表于 2019-9-15 09:09:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Remain safe no matter what. Do what’s in the best interest of you. You are in control of that truck and only you can determine if you will get you job done safely. Always keep dispatch up to date and you’ll be fine","replyToPid":0}
发表于 2019-9-21 01:47:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"run.  run fast.   lol","replyToPid":0}
发表于 2019-9-21 13:55:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"always remember.  ur (GOAL) Get out and look only takes a minute when in daught gauge on it and keep going","replyToPid":0}
GMT+8, 2026-4-18 07:01 , Processed in 0.120137 second(s), 24 queries .
