查看: 164|回复: 1
Cascadia Brake lights on when pedal released
 楼主| 发表于 2019-1-24 18:16:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have 2017 cascadia model and tractor brake lights acting.\nWhen I release brake pedal stop lights stay on. If the truck is not running and trailer not connected -same thing lights are acting. I checked fuses , all good. I went to dealership they could not find problem...I read online that this might be upcoming recall. Perhaps ahybody had this problem and knows what was replaced to fix it?","pics":"[]","canComment":true}
发表于 2019-3-5 05:07:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"You may need to change the brake switch. It's located behind the gas pedal behind the panel. I don't remember how much it cost but I end up changing all of those when I I had an issue with my parking brake warning light. But that issue was because a lose connection under the sam cab. It was probably less than $20 it. Easy fix. The tags on the switches identify which one it is. There's 2 for the pressure sensors and the top 1 is the parking brake switch. If not that change the brake pressure sensors. You should bleed out your air when changing the pressure sensors cuz if you don't air that air is going to blow out when you unscrew it.","replyToPid":0}
GMT+8, 2026-4-17 06:07 , Processed in 0.077253 second(s), 24 queries .
