查看: 91|回复: 7
Best advice from your parents?
 楼主| 发表于 2019-9-11 05:30:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"They told to always look and appreciate what you have and always strive for better.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-11 23:19:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"\"you can ride a downgrade thousands of times too slow but only once too fast. don't let the others behind you pressure you. there's a passing lane on downgrades too.\"","replyToPid":0}
发表于 2019-9-11 19:27:13 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"due on to others as you want done to you\n\nkarma is real and she bites hard"}
发表于 2019-9-11 20:26:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"never judge other people judge yourself","replyToPid":0}
发表于 2019-9-12 11:00:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you're early you're on time, if you're on time you're late!","replyToPid":0}
 楼主| 发表于 2019-10-6 01:50:31 来自手机 | 显示全部楼层
764851 发表于 2019-09-11 11:27:13 due on to others as you want done to you\n\nkarma is real and she bites hard
","text":"True that","replyToPid":205842}
 楼主| 发表于 2019-10-6 01:50:37 来自手机 | 显示全部楼层
655774 发表于 2019-09-11 12:26:14 never judge other people judge yourself
","text":"Good one","replyToPid":205862}
 楼主| 发表于 2019-10-6 01:50:54 来自手机 | 显示全部楼层
731713 发表于 2019-09-11 15:19:17 \"you can ride a downgrade thousands of times too slow but only once too fast. don't let the others behind you pressure you. there's a passing lane on downgrades too.\"
","text":"gold 👌","replyToPid":205930}
GMT+8, 2026-4-20 03:16 , Processed in 1.156747 second(s), 24 queries .
