查看: 198|回复: 5
Personal Conveyance
 楼主| 发表于 2019-9-11 04:32:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"If you are relocating to another company and have to drive 13 hours to new co. Can you drive it under PC?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-12 00:06:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"call your local Werner recruiter they can help you after all they are the company that got the elog shoved up all our arses","replyToPid":0}
发表于 2019-9-11 09:28:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"From my understanding of the latest guidance applied to the personal conveyance rule, so long as you are not advancing a load, you can drive from NYC to LA with/without a loaded/empty trailer. I would not recommend exceeding 11hrs of driving time and be sure to document a daily pre-trip whether it be a paper copy or electronic as that is still required regardless of PC. \n\nhttps://www.fmcsa.dot.gov/regulations/hours-service/personal-conveyance","replyToPid":0}
发表于 2019-9-11 09:07:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Simple answer No. \n\nDo you have a trailer attached or are you bobtail? ","replyToPid":0}
发表于 2019-9-11 21:01:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes, has nothing to do with a load.","replyToPid":0}
发表于 2019-9-12 05:52:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re driving a personal vehicle there’s no need to list it. If you’re OO you can drive PC literally across the country and back and still be in compliance. As long as you’re not hauling anything but sailboat fuel that is.","replyToPid":0}
GMT+8, 2026-4-18 04:07 , Processed in 0.074379 second(s), 24 queries .
