查看: 300|回复: 21
Can you take Cdla test with dually and trailer?
 楼主| 发表于 2019-5-22 04:12:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm just wondering.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-22 05:42:55 来自手机 | 显示全部楼层
596577 发表于 2019-05-21 21:18:05 they might restrict ur license with automatic only
","text":"no you cannot at least not a Class A CDL","replyToPid":40094}
发表于 2019-5-22 06:09:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"you cannot pass a Class A CDL test with a dually pickup truck and a trailer due to the fact you cannot do a walk-around and pouring out to the dot inspector the air brake system on there. because there is no air brake system on a dually pickup truck therefore you can't pass the test... but what you could do is get a Class C CDL with that combination... this is exactly what my brother does in Arizona he is a dot inspector and does the testing of all new drivers coming out of the school. so if you are telling me that you have a Class A CDL that you obtained by testing with a dually pickup truck and a trailer you are full of XX XX","replyToPid":40146}
发表于 2019-5-22 11:39:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Next question: can I take my CDL test with my Prius? ","replyToPid":0}
发表于 2019-5-22 06:11:49 来自手机 | 显示全部楼层
发表于 2019-5-22 04:17:02 来自手机 | 显示全部楼层
发表于 2019-5-24 04:30:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤣🤣🤣🤣 a comedian","replyToPid":40009}
发表于 2019-5-24 04:31:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"🙄🙄🙄🤣🤣🤣","replyToPid":40146}
发表于 2019-5-24 04:31:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"NO YOU DIDN'T","replyToPid":40166}
发表于 2019-5-22 05:18:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"they might restrict ur license with automatic only","replyToPid":0}
发表于 2019-5-22 09:03:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"You are 100% right if you do not have a class A CDL, A class C driver can not drive a semi Tractor, LMFAO a pickup with a trailer 🤣🤣🤣😂😂","replyToPid":0}
发表于 2019-5-22 05:59:05 来自手机 | 显示全部楼层
发表于 2019-5-22 06:14:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"ooooook","replyToPid":40166}
发表于 2019-5-22 06:14:44 来自手机 | 显示全部楼层
发表于 2019-5-22 06:16:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"if ur trailer weighs 10,001 or more u need a class A no matter the towing vehicle they would restrict ur license","replyToPid":0}
GMT+8, 2026-4-18 13:58 , Processed in 0.090803 second(s), 24 queries .
