查看: 233|回复: 7
oil changes
 楼主| 发表于 2019-9-11 00:51:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"I was thinking about oil changes the other day. now some do it every 15,000 miles then others do it all the way at 45,000 miles. now the different types oil. Weight/synthetic etc. \nlet's say you do your full oil change at 15,000 miles. say at speedco. \nthey ask what type of oil regular,synthetic,full synthetic or bulk. \nyou go synthetic mobile 5w 30.  \nthe person next to you says synthetic bulk. 5w 30\nwhat's the Difference? \n\nnow synthetic oil is oil with an synthetic additive. \nit's regulated by PPM whether it full or regular synthetic \n\nThink about this. the driver getting bulk oil. pay's 50.00 less than you not only that he changes his oil every 45,000 miles but every 15,000 miles he changes his oil filter dies a oil sample and tops off.\n30,000 same as 45,000 etc \n\nso who is the crazy one \n15,000\n30,000\n45,000\n\nnow think about this. bulk oil. every truck that has there oil changed no matter what type 5w 10w regular synthetic etc. is recycled and sold back to various oil changing places. \nsince it's recycled if you ask for regular bulk oil is it regular or is it synthetic? with a lower PPM? \nsomething about oil. the only way oil is bad is if it's burnt. (true fact) that's why they recycle oil. so in reality which owner operator is saving on oil changes? \n\nThis whole question is mine alone. I'm not suggesting anyone change there maintenance program. but if you do decide to change talk to the appropriate person and the manufacturer on oil changes...","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-11 03:07:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"What about bypass filtration systems?","replyToPid":0}
发表于 2019-9-11 02:33:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bobistheoilguy.com has all the info one needs related to oil.","replyToPid":0}
发表于 2019-9-11 02:51:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"1st stop doing oil changes at Speedco,  there quality drop after Love's bought them. I do my oil changes on Detroit DD15 in between 15k to 20k miles not more. If some is doing at 30k after. voiding Warranties. I'm doing that from day one have 1.2 million MILES never done a rebuild on engine yet. I do 15w40 thick oil more lubricity, once u go  full synthetic can't go back, will drop ur mpg big time.","replyToPid":0}
发表于 2019-9-11 02:51:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are using the regular oil I would say up to 13-14k max! The synthetic blend is ok up to 45k but you gotta do filters in between because they are not designed for that long of a run! ","replyToPid":0}
发表于 2019-9-11 03:02:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use the Shell Rotella 15 w40 and I change my oil every 15000 miles. I have been using that oil and changing the oil at those intervals for years","replyToPid":0}
发表于 2019-9-11 21:39:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I'm having a hard time understanding what the question is or even what you're talkin about. I use 15w-30 oil, ck4 rated. I change the oil when I feel like it's been a long time, I do it myself where I park my truck. \n\nI used to use 15w 40, that cheap oil from Delco, but I noticed the engine made a lot more noise and you lose one mile per gallon in fuel.\n\nmy understanding of oil is that there's standard oil, synthetic blend, and full synthetic. The difference between standard oil and synthetic is thatsynthetic is more fluid at lower temperatures which is good for winter conditions. I will be using full synthetic in the winter, but I save money in the summer and go with a synthetic blend."}
发表于 2019-9-14 09:33:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do Rotella 15/40  with one gallon of Lucas every 12-15K.","replyToPid":0}
GMT+8, 2026-4-18 02:50 , Processed in 0.099512 second(s), 24 queries .
