查看: 244|回复: 6
why isn't my TruckerPath showing the scales ?
 楼主| 发表于 2019-9-10 05:15:57 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-9-10 05:35:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you make sure they were turned on through the “places” button?","replyToPid":0}
 楼主| 发表于 2019-9-10 08:59:05 来自手机 | 显示全部楼层
599477 发表于 2019-09-09 21:35:03 Did you make sure they were turned on through the “places” button?
","text":"yes, it's on.","replyToPid":204767}
发表于 2019-9-10 09:17:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"try install and uninstall","replyToPid":0}
发表于 2019-9-10 10:27:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Select places at bottom left of map>>> select scales >>>> then they should populate! If this doesn't work try updating the app. If still no success reach out to the truckers path staff!","replyToPid":0}
发表于 2019-9-10 21:59:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes I know to turn them on... they ain't loading","replyToPid":0}
发表于 2019-9-10 23:29:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi there!\n\nThank you for raising this to our attention. This is a known issue that our development team is fixing. As of now, please uninstall and reinstall the app and everything should work normally.\n\nHave a great day ahead!","replyToPid":0}
GMT+8, 2026-3-21 06:10 , Processed in 0.092089 second(s), 24 queries .
