查看: 361|回复: 19
Hi
 楼主| 发表于 2019-9-9 13:10:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-10 03:23:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't mean to burst your bubble but it will be the worst mistake you ever made :\n\nhttps://youtu.be/cfXvltU4mOs","replyToPid":0}
发表于 2019-9-9 21:17:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ask for maintenance records I’m sure nothing much has been done to the truck yet you will have a lot of repairs coming soon can you afford them it will be lots money 💰 and down time","replyToPid":0}
发表于 2019-9-10 12:11:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I have an extra truck I’ll sell ya it’s a international has 401k on it has a bumper to bumper warranty still till 500 k  I bought a Kenworth and don’t use it just sits at home while I drive my other truck. 50 k. Definitely worth it Double bunk 13 speed. dd 15. "}
发表于 2019-9-10 02:39:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"this might sound stupid but when you get the maintenance records check for water leaks being repaired, possibly multiple times. That seems to be a big problem with Cascadias. Mine has been a pain, I've had the sam cab box replaced twice and the sam chassis box replaced once & the windshield & clearance lights resealed several times. I think the body shop at the Freightliner in Knoxville finally did it right, haven't had a problem for quite a while.","replyToPid":0}
 楼主| 发表于 2019-9-10 02:33:15 来自手机 | 显示全部楼层
295387 发表于 2019-09-09 13:17:59 Ask for maintenance records I’m sure nothing much has been done to the truck yet you will have a lot of repairs coming soon can you afford them it will be lots money 💰 and down time
","text":"You might be right,i have same feelings for this truck ","replyToPid":204477}
 楼主| 发表于 2019-9-10 02:29:27 来自手机 | 显示全部楼层
567641 发表于 2019-09-09 12:45:54 check compression every cylinder don't buy if differences in cylinders more then 1.0 psi 18.4 new .....oil leaks main seal and  stored codes, dpf system, (A1 box)...differential ratio more for heavy houl?? 2.85 3.25 but 13 speed with 3.75 probably ok\n1500 rpm you  should be able to go 75 mph price is ok if original miles
","text":"Thanks,how to check compression every cylinder?","replyToPid":204474}
发表于 2019-9-9 20:45:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"check compression every cylinder don't buy if differences in cylinders more then 1.0 psi 18.4 new .....oil leaks main seal and  stored codes, dpf system, (A1 box)...differential ratio more for heavy houl?? 2.85 3.25 but 13 speed with 3.75 probably ok\n1500 rpm you  should be able to go 75 mph price is ok if original miles","replyToPid":0}
发表于 2019-9-9 20:47:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"us about 28000$ for same truck","replyToPid":0}
 楼主| 发表于 2019-9-10 02:27:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Actually he just told me DPF working 22% ,I will upload ecm report tomorrow,its Penske rental truck .","replyToPid":0}
发表于 2019-9-10 08:34:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"when they hook up the computer will show you all cylinders if 4 are at let's say 17.5 .and1 is at 16.8 and15.3 engine is going bad all have to be same psi + - .2psi ...penske are b s tray to get from quest near Macon GA or ex big company a lot of the big companies sell them at 500 000ml","replyToPid":0}
GMT+8, 2026-4-18 07:12 , Processed in 0.085290 second(s), 24 queries .
