查看: 83|回复: 0
Coolant hoses.. Mack
 楼主| 发表于 2019-1-24 18:14:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"These coolant hoses are cracking on me from the clamps, is this very normal or do I have a bigger problem building pressure? In this pic the hoses cost 300$ it's leaking really bad lost half a gallon of coolant today. Should I loosen the clamps and push the hose up and try to save changng the hose or is it time to change it? Leaking from the top of the hose after the clamp","pics":"[{\"description\":\"\",\"height\":100.0,\"name\":\"0/ios_15483248582900.png\",\"url\":\"\",\"width\":75.0}]","canComment":true}
GMT+8, 2026-4-17 06:23 , Processed in 0.069966 second(s), 23 queries .
