查看: 65|回复: 0
12VDC vs. 24VDC Inverter Question
 楼主| 发表于 2019-9-9 05:53:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a general question about what members may recommend to use for a reliable PURE sign inverter I can \"grow into\". I would like to use in a 1997 F350 with (2) 12V batteries. Should I strictly use a 12VDC input inverter or do I need to bump up to a 24VDC input because of the two batteries. My thinking is to not underpower the inverter so stick with a 12VDC? I believe the 24VDC inverters require the need to maintain higher voltage input to eliminate damage to inverter and may be more of an \"off the grid\" application? My needs don't require a 24VDC inverter but my truck has two batteries. Any input would be greatly appreciated.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
GMT+8, 2026-4-18 04:07 , Processed in 0.125397 second(s), 23 queries .
