查看: 180|回复: 6
Final hours of OTR training.
 楼主| 发表于 2019-9-9 02:04:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m only 30hrs away from finishing I’m on reset and decided to hook up to an empty trailer to practice backing. Guess I chose the wrong trailer coupled did tug test, hooked up air lines and pig tail lifted the landing gear. All set and ready to roam around a semi empty terminal parking lot to practice my backing. Well the red air line keeps popping off and loosing a crap load of air. Decided to uncouple now can’t pull the darn king pin release arm. Unhooked air lines set them back again same crap loosing a bunch of air glad hand seals are good but still loosing air. Wtf is wrong ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-12 17:40:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could be improper fit, loose restraint, blown seal.  Back up with trailer brakes locked to relieve the pressure on the 5th wheel lockjaw.","replyToPid":0}
 楼主| 发表于 2019-9-16 11:50:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"It had a major air leak, had to lift the landing gear pretty high so I could unhook. Thank you ","replyToPid":0}
发表于 2019-9-17 11:13:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could be you do not have the red side to the red side. Check that.  You press pedal it blows off lol","replyToPid":0}
发表于 2019-9-17 11:18:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"A pair of legs and torso walking in a hurry across Hwy 9 in Alabama. No I was not high lol.","replyToPid":0}
发表于 2019-9-21 01:41:32 来自手机 | 显示全部楼层
462367 发表于 2019-09-17 03:18:07 A pair of legs and torso walking in a hurry across Hwy 9 in Alabama. No I was not high lol.
","text":"pictures or it didn't happen. lol","replyToPid":209243}
 楼主| 发表于 2019-9-26 05:21:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"They were connected properly. The red air line was just loose and actually trailer was not good. ","replyToPid":0}
GMT+8, 2026-4-18 04:07 , Processed in 0.090818 second(s), 24 queries .
