查看: 106|回复: 0
Eaton Fuller 8LL Splitter not Engaging
 楼主| 发表于 2019-1-24 18:13:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Got in the truck today and it is stuck in gear. The shifter is in neutral but the truck is in gear. When I flip the range selector works, I can hear the clunk. But when I toggle the Splitter, I hear the air but nothing else..\nI do have some oil in my wet tank , which I will be taking care of in the morning I've heard that can cause the Eaton to get all gunked up inside and cause this. Appreciate any help, ideas or opinons.\n\nBTW, it is in 2001 KW T800 Superdump","pics":"[]","canComment":true}
GMT+8, 2026-2-4 16:57 , Processed in 0.048619 second(s), 23 queries .
