查看: 194|回复: 2
Please Don't Laugh at Me...2WD vs 4WD when using a dually?
 楼主| 发表于 2019-1-24 18:12:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"This question is strictly for diesel duallies pulling wedges and flatbeds.\n\nI understand that the 2WD will be more efficient, and that 4WD/AWD will guzzle gas more.\n\nI want to know, from an experienced hauler, from someone with mechanical knowledge, which is the righ choice *for my particular situation*...which is sounding like it is not the norm for others in the industry.\n\nPlease keep in mind, I will be leaving the yard at 7:30am each day, empty. I will then go about my daily loads, ALL of them being within 100 miles of Atlnata, and NEVER crossing state lines. This is a strictly intrastate rig/setup. I am basically shuffling cars around for local dealerswaps and auction buys.\n\nI will never be sleeping in this truck. It will never be loaded anywhere close to its max GVWR. And the suburbs of Atlanta aren't too challenging as far as hills go.\n\nThe thing that made me wonder about it is there is an option on the (new) F350 Super Duty's that allows you to switch from 2WD to 4WD on the fly. Pretty cool if you ask me. Is it worth the $3000 for the 4x4 package or should I stick with the 2WD?\n\nI appreciate all input.","pics":"[]","canComment":true}
发表于 2019-3-13 02:55:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hey man had a 2wd and a 4wd drive dodge 4500 dually just get ready for breaks. The trucks can’t handle the weight especially if u travel through pa and oh where there are many uphillls   My transfer case broke on 4500 and the def was a night mare always got clogged and the truck wouldn’t pull. ","replyToPid":0}
发表于 2019-4-3 22:22:15 来自手机 | 显示全部楼层
634202 发表于 2019-03-12 18:55:09 Hey man had a 2wd and a 4wd drive dodge 4500 dually just get ready for breaks. The trucks can’t handle the weight especially if u travel through pa and oh where there are many uphillls   My transfer case broke on 4500 and the def was a night mare always got clogged and the truck wouldn’t pull.
","text":"4wd you are allowed more weight. ","replyToPid":4824}
GMT+8, 2026-4-17 23:49 , Processed in 0.078245 second(s), 23 queries .
