查看: 939|回复: 69
Strange bouncing from the steer axle... 🤷🏻‍♀️
 楼主| 发表于 2019-9-8 00:29:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’ve got a weird bouncing/ shaking when driving down the road and I don’t know how to make it stop or what to do to fix it. It feels like it’s coming from the driver side steer. I’ve replaced my steers twice in 40,000 miles. Now have really good Michelin’s. Got them balanced, done a 3 axle alignment, got Centramatics put in, and replaced the wheel/rim on the driver’s side. Still bouncy, and the steering wheel is starting to shake again too. And no, I haven’t hit anything so far. Help?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-8 09:27:43 来自手机 | 显示全部楼层
{"replyToPid":203403,"replyTo":"
599477 发表于 2019-09-07 22:05:00 Yeah it’s on the inside of the left tire and outside of the right. I had the last tires balanced. And now I have the Centramatics...
","text":"that wear pattern doesn't suggest balance issue, your scrubbing your tires not bouncing them. sounds like a bad 3 axle alignment. are you holding your wheel more to the right or left?\n\nyour caster- camber could be off. meaning your dragging your front axle rather than riding on top of it. few shops check this when doing an alignment unless you specifically ask."}
发表于 2019-9-8 05:43:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you been on rough highway you may need to grease front end down  I grease our rig every two weeks good ball joints just beats it out the front end after grease job I’m good go until the rough roads again ,, plus wore kink pins do that to ","replyToPid":0}
发表于 2019-9-8 06:15:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"That worries me when front end isn’t right seen a lot recks from that  steer tires to tire rods bearings I do not have a lot of confidence in loves when it comes to work on trucks I do all our maintenance every week usually Sunday and I don’t trust a lot of shop neither , just be careful glad your not ignoring me he issues 👍","replyToPid":0}
发表于 2019-9-9 04:46:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wonder why it is bouncing. 🤔🤔🤐😬😈😸😹","replyToPid":0}
 楼主| 发表于 2019-9-8 23:58:25 来自手机 | 显示全部楼层
310244 发表于 2019-09-08 01:54:31 My truck.... she runs straight down the highway for a long time until she starts to wander, usually because of a bump in the road. 😉👍🏼
","text":"I feel like Wyoming roads throw out my alignment instantly 😒","replyToPid":203565}
发表于 2019-9-8 09:51:21 来自手机 | 显示全部楼层
599477 发表于 2019-09-08 01:09:55 Drum unfortunately. But I definitely will. How is their cost compared to others?
","text":"MD is the best, as far as I’m concerned. The service they provide is exceptional... and the father/son team who own the name... always available to help: just a phone call away.\n\nPrice is a minor issue... when I want a job done, I want it done right the first time. If it’s a few dollars more... but I never have to deal with it again, that’s money well spent.\n\nLoves is good, at certain things. Alignment... I’ll pass.","replyToPid":203550}
 楼主| 发表于 2019-9-8 06:12:29 来自手机 | 显示全部楼层
755304 发表于 2019-09-07 22:11:39 Have you had you wheel bearing check lately
","text":"Yep with last week’s PM","replyToPid":203423}
发表于 2019-9-8 06:11:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you had you wheel bearing check lately ","replyToPid":0}
 楼主| 发表于 2019-9-9 00:02:25 来自手机 | 显示全部楼层
623679 发表于 2019-09-08 02:06:55 With the roads the way they are I had a pretty good vibration in the front end, I ended up blowing both shocks on my 2019 freightliner, 2 weeks later blew the driver side again, and no problems since
","text":"Ooh I haven’t thought about the shocks! Thank you! ","replyToPid":203581}
 楼主| 发表于 2019-9-8 08:02:03 来自手机 | 显示全部楼层
596323 发表于 2019-09-07 22:34:52 Yeah I just saw the rest of the post. Sorry I missed that. I was going to recommend the centramatics but you’ve already covered all I was going to recommend....maybe a kingpin issue? How thorough are the mechanics about greasing the trucks?
","text":"I watched them do it this last time. ","replyToPid":203476}
发表于 2019-9-8 03:17:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is it shaking all the time or when you hit your brakes","replyToPid":0}
 楼主| 发表于 2019-9-8 03:25:16 来自手机 | 显示全部楼层
295387 发表于 2019-09-07 19:17:03 Is it shaking all the time or when you hit your brakes
","text":"Always. Usually noticeable at highway speed","replyToPid":203270}
发表于 2019-9-8 04:28:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m guessing a balancing issue. Have you noticed any irregular wear on your steer tires? Cupping or more noticeable wear to the outer edges of you tires? ","replyToPid":0}
发表于 2019-9-8 05:44:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Some 2014 to 2016 Freightliners have a Hendrickson 5 inch drop axle that is defective and can break anytime leaving you without steering. I hope that isnt  the case.","replyToPid":0}
 楼主| 发表于 2019-9-8 06:05:00 来自手机 | 显示全部楼层
596323 发表于 2019-09-07 20:28:14 I’m guessing a balancing issue. Have you noticed any irregular wear on your steer tires? Cupping or more noticeable wear to the outer edges of you tires?
","text":"Yeah it’s on the inside of the left tire and outside of the right. I had the last tires balanced. And now I have the Centramatics... ","replyToPid":203290}
 楼主| 发表于 2019-9-8 06:06:31 来自手机 | 显示全部楼层
755304 发表于 2019-09-07 21:43:50 If you been on rough highway you may need to grease front end down  I grease our rig every two weeks good ball joints just beats it out the front end after grease job I’m good go until the rough roads again ,, plus wore kink pins do that to
","text":"I had Love’s do that when they did my PM last week. Didn’t fix it. ","replyToPid":203360}
GMT+8, 2026-3-20 22:42 , Processed in 0.111024 second(s), 24 queries .
