查看: 267|回复: 19
Man if you don’t have this on your steering wheel your working way to hard a must have tool for backing
 楼主| 发表于 2019-9-7 00:44:57 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-9-7 00:57:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Illegal in the US as well. Just not enforcing it.","replyToPid":0}
发表于 2019-9-7 01:16:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Eh, tried it. Didn’t like it","replyToPid":0}
发表于 2019-9-9 04:03:28 来自手机 | 显示全部楼层
669593 发表于 2019-09-08 19:32:09 Make Backing into hard parking spots so easy I swing that trailer into a spot like a 30 year vet 💯
","text":"I dont need tools or aids to get the job done ","replyToPid":204003}
发表于 2019-9-7 00:46:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Illegal in many part of canada","replyToPid":0}
发表于 2019-9-13 09:58:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I never had a problem with it on at any DOT inspection didn't even look at it","replyToPid":0}
发表于 2019-9-13 09:56:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree I got one it makes it easier to back up","replyToPid":0}
发表于 2019-9-17 12:00:36 来自手机 | 显示全部楼层
669593 发表于 2019-09-16 20:53:39 I’ve got stopped like 5 times and in many states no officers has said nothing about it
","text":"https://www.govinfo.gov/content/pkg/CFR-2003-title49-vol4/pdf/CFR-2003-title49-vol4-sec391-49.pdf\n\nUnless you fall under the ADA protections for a reasonable accommodation for one to be installed and used in order for you to physically be able to perform your duties, and have the proper medical forms and clearance filed for a medical exception, they are in fact illegal to use. Here’s the 49 CFR for its legal usage.  They’re legal on passenger vehicles, farm equipment, forklifts, and construction equipment, but not on CMVs per OSHA and FMCSA. Like I said before, you’ve just been lucky.","replyToPid":209016}
发表于 2019-9-17 11:32:28 来自手机 | 显示全部楼层
","text":"Then ya just haven’t met the di$k one yet because here in the states they’re illegal. I’ll see if I can find the law for it and post it for you.","replyToPid":209016}
发表于 2019-9-13 21:20:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"They’re actually illegal in many places ","replyToPid":0}
发表于 2019-9-7 03:22:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Negative","replyToPid":0}
发表于 2019-9-7 09:21:20 来自手机 | 显示全部楼层
103619 发表于 2019-09-06 18:43:58 arent those the x large anal plugs??  we gave put to the cry babies??? or for when you miss your bf and got a knob to rub??
","text":"😂😂😂😂","replyToPid":202821}
发表于 2019-9-8 21:32:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"illegal  last I heard","replyToPid":0}
 楼主| 发表于 2019-9-9 03:32:09 来自手机 | 显示全部楼层
","text":"Make Backing into hard parking spots so easy I swing that trailer into a spot like a 30 year vet 💯 ","replyToPid":202821}
 楼主| 发表于 2019-9-9 08:06:59 来自手机 | 显示全部楼层
103619 发表于 2019-09-08 20:03:28 I dont need tools or aids to get the job done
","text":"Handle your Business then 💯","replyToPid":204023}
GMT+8, 2026-2-11 08:59 , Processed in 0.120157 second(s), 24 queries .
