查看: 99|回复: 5
truck refrigerator
 楼主| 发表于 2019-9-6 05:21:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"So what did you do for a frig? Standard '16 Freighliner Cascadia. Can you share a model that fits this space? Did you convert space by combining upper and lower cabinet space?\nHow is the quality of the Coleman cooler frig at Loves for $129? Any input welcome. Thanks.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2019-9-6 08:57:56 来自手机 | 显示全部楼层
22378 发表于 2019-09-05 23:52:33 Dont do the Coleman unless you plan on hardwiring it...because the cigarette lighter tip will melt off withing 72 hrs of state continuous use.
","text":"Wrong! I have one 4yrs and never had a problem!!","replyToPid":202357}
发表于 2019-9-6 07:52:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dont do the Coleman unless you plan on hardwiring it...because the cigarette lighter tip will melt off withing 72 hrs of state continuous use.","replyToPid":0}
 楼主| 发表于 2019-9-7 07:08:15 来自手机 | 显示全部楼层
","text":"good info ty.","replyToPid":202357}
发表于 2019-9-7 10:20:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Count yourself lucky my friend, I have a grave yard of them. I cant figure out why, but the cigarette light tips melts off every one. I've even tried replacing them with the \"Heavy Duty\" Wilson tips...melted overnight.","replyToPid":0}
发表于 2019-9-7 10:21:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh and to the OP, just incase you decide to grab 1 anyway, it doesn't fit into that space.","replyToPid":0}
GMT+8, 2026-2-10 20:45 , Processed in 0.091617 second(s), 24 queries .
