查看: 124|回复: 3
Pay
 楼主| 发表于 2019-9-5 22:49:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is it worth becoming an owner op. Also how the off time?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-6 07:26:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"No such thing as off time as o/o","replyToPid":0}
发表于 2019-9-8 09:06:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"you are off when you can afford it, when your truck is in the shop, when there is no loads","replyToPid":0}
发表于 2019-9-8 09:32:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"There's alot that factors into \"if its worth becoming a o/o\" and most of that depends on you. Are you financially ready to buy a truck, how hard do you run ect. Theres alot to being a successful o/o. As for home time it mainly depends on how your set up financially if you can afford to take any time off.","replyToPid":0}
GMT+8, 2026-4-18 02:52 , Processed in 0.710976 second(s), 24 queries .
