查看: 310|回复: 21
Tandem Stopper
 楼主| 发表于 2019-9-4 23:36:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello I have A question does anyone know where I can Purchase this tool from?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1134.0},{\"description\":\"\",\"height\":1608.0,\"name\":\"\",\"url\":\"\",\"width\":2268.0}]","canComment":true}
发表于 2023-3-17 12:16:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fnnnews knows where to pull one out of.","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-9-5 03:40:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Iowa 80","replyToPid":0}
发表于 2023-3-17 08:55:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dam!!!! You really like big shaft ","replyToPid":0}
 楼主| 发表于 2019-9-5 23:58:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"you out it where you want to slide your tandem and when you get to where you what is set it will stop you from passing your mark","replyToPid":202163}
 楼主| 发表于 2019-9-5 23:58:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank I will check","replyToPid":201580}
发表于 2019-9-6 07:31:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh goodie a new toy I can purchase to simplify life! Thanks for posting.","replyToPid":0}
发表于 2019-9-5 21:35:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've been driving a long time didn't know that even existed. Learn something every day","replyToPid":0}
发表于 2019-9-5 19:58:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Amazon","replyToPid":0}
发表于 2019-9-5 20:28:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Krome shop..","replyToPid":0}
发表于 2019-9-5 23:12:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"how does it work?","replyToPid":0}
 楼主| 发表于 2019-9-5 23:56:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you of the info","replyToPid":0}
发表于 2019-9-5 23:58:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"You put it in the hole next to where you want to slide your tandems to. Makes it perfect. 😁","replyToPid":202163}
GMT+8, 2026-2-6 03:48 , Processed in 0.559303 second(s), 24 queries .
