查看: 59|回复: 0
Pro tip #4
 楼主| 发表于 2019-9-3 09:10:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do not think that someone that talks like a pro trucker can actually drive like one. Do not follow a truck you observe tailgating, speeding, or swerving because they are distracted and put more space between you and them. If someone is tailgating you don’t brake check them, just slow down a little and let them pass you. If you see trucks with flashers on driving 35 mph in Oklahoma at 2AM there is likely black ice so don’t continue to drive the speed limit.","videos":"[]","link":"{}","pics":"[]","canComment":true}
GMT+8, 2026-4-18 04:07 , Processed in 0.070696 second(s), 23 queries .
