查看: 69|回复: 0
Pro tip #1
 楼主| 发表于 2019-9-3 08:48:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"When backing into a proper spot at a truck stop, please do a) get out and look but check to see if there are any obstacles in the rear of the spot you might hit but if there are none, back all the way until your wheels touch the curb gently. Many of the macho so called experienced drivers are setting a poor example by only putting the trailer in the spot and leaving the truck sticking out in the driveway.","videos":"[]","link":"{}","pics":"[]","canComment":true}
GMT+8, 2026-4-18 07:01 , Processed in 0.072637 second(s), 23 queries .
