查看: 209|回复: 18
what do you do if a working refer and apu trk park right next to you IN EMPTY PARKING LOT? (300 + spaces) i moved...
 楼主| 发表于 2019-9-3 02:36:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1134.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true}
发表于 2019-9-3 07:36:05 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Trucks like parking next to each other. Especially in places that don’t exactly have truck parking, it’s best to stay together.\n\nI drive reefer and I have to admit I often forget that non reefer drivers aren’t used to the noise and are bothered by it. I’ve been reefer 5 years so I don’t even notice it anymore. \n\nSo on behalf of us unintentionally inconsiderate reefer drivers, sorry. "}
回复 支持 10 反对 0
发表于 2019-9-5 02:44:58 来自手机 | 显示全部楼层
679939 发表于 2019-09-04 16:16:26 How's a reefer's  noise louder than a diesel engine noise?
","text":"Its not about the decibel or noise level... the pitch of a refer can easily penetrate a sleeper a truck over when in high idle mode. cycle century is notorious for it. when I hauled reefer, id set it to continuous that way it remained in low idle throughout the night,  and was less disruptive to others...","replyToPid":201453}
发表于 2019-9-3 10:31:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"I be glad it parked there. safety in numbers","replyToPid":0}
发表于 2019-9-5 05:51:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"move fwd or back so your sleeper is not by the reefer. i feel the same way about guys with apu they are quite loud too","replyToPid":0}
发表于 2019-9-5 03:17:42 来自手机 | 显示全部楼层
449144 发表于 2019-09-04 18:44:58 Its not about the decibel or noise level... the pitch of a refer can easily penetrate a sleeper a truck over when in high idle mode. cycle century is notorious for it. when I hauled reefer, id set it to continuous that way it remained in low idle throughout the night,  and was less disruptive to others...
","text":"thank you!  I don't mind reefers unless it's what I think of a screaming reefers.","replyToPid":201511}
发表于 2019-9-3 02:39:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"move.  and thanks to elds move very slowly.","replyToPid":0}
发表于 2019-9-7 03:26:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"what is yall problem with reefers? I dont understand. so what if they park next to you in an empty lot, there is no designated spots for certain trucks to park. You would probably say the same thing even if the lot was full. \nTell you what, you want to be by yourself, find an abandoned area, with no services. there is your peace and quiet...it is trucking, stop whining!!! Sheesh!!","replyToPid":0}
发表于 2019-9-3 02:38:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Reefer is always the way to go.","replyToPid":0}
发表于 2019-9-5 07:31:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s insane and done with intent. ","replyToPid":0}
 楼主| 发表于 2019-9-3 07:09:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"if the lot is full  I'll understand no problem","replyToPid":0}
 楼主| 发表于 2019-9-3 02:43:07 来自手机 | 显示全部楼层
792713 发表于 2019-09-02 18:38:20 Reefer is always the way to go.
","text":"ok,nothing against reefers, but way next to me its  empty lot?","replyToPid":199761}
发表于 2019-9-3 02:43:42 来自手机 | 显示全部楼层
567641 发表于 2019-09-02 18:43:07 ok,nothing against reefers, but way next to me its  empty lot?
","text":"Company","replyToPid":199775}
发表于 2019-9-3 04:02:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would go to sleep......but I’m pretty lazy.  I mean, if the lot was full what would you do? Leave?","replyToPid":0}
发表于 2019-9-3 07:13:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"*** * ** *****?","replyToPid":0}
GMT+8, 2026-2-10 15:29 , Processed in 0.133639 second(s), 24 queries .
