查看: 117|回复: 4
Chains or AutoSocks?
 楼主| 发表于 2019-9-3 01:32:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Well, I moved out to Northern Colorado from NY, became an owner op, started doing enclosed hotshot, and just got back doing two runs into the mountains to Aspen and back (Loveland & Vail Pass) this Labor Day weekend. Last week I did a run from Steamboat Springs (Loveland Pass) to Denver and the week before that I did Monarch Pass (11,000ft+) a couple times. It’s officially Sept. 2nd and as of yesterday they require you to have chains on hand when going over I-70 or any roads up there. \n\nHere are my questions, what do you guys use for your big rigs (or hotshots), Snow Socks or Chains?\n\nIf you compared the Snow Socks to Chains, what did you end up going with and why?\n\n\nBtw, What carnage there is on I-70 of overheating, broken down trucks, rv’s, and cars!! Every time I go up there I see more than a handful of vehicles overheated in one way or another. I’m going to get some footage one of these times and post it up. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"Glenwood Canyon\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-9-3 03:50:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you chain a lot maybe look into auto chains. I see them all the time on eBay for cheap.","replyToPid":0}
发表于 2019-9-3 03:48:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"chains. tire socks are too easily damaged. throwin iron isn't that bad just don't drive 50 mph chained up. got passed last winter in Washington by a guy that had his steers chained and he was hauling. couple miles down the road he was on the shoulder with hood open and a huge puddle of fuel underneath. looked like chain broke or came loose and took the fuel filter out 😆😆","replyToPid":0}
发表于 2019-9-3 02:49:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Loveland Pass is no where near Steamboat Springs.","replyToPid":0}
 楼主| 发表于 2019-9-7 08:37:07 来自手机 | 显示全部楼层
792713 发表于 2019-09-02 18:49:54 Loveland Pass is no where near Steamboat Springs.
","text":"If you’re going to Denver then yes it is. That’s the quickest route over Loveland Pass. ","replyToPid":199791}
GMT+8, 2026-3-21 18:17 , Processed in 0.079074 second(s), 24 queries .
