查看: 110|回复: 4
Axle weights during winter
 楼主| 发表于 2019-9-2 08:44:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"Make sure you have more weight on your drives than your tandems during the winter months to avoid jackknifing.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-13 21:56:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not necessarily true. Lose traction on the tandem with little weight means that trailer is coming to meet you up close and personal. Even distribution of weight not only provides more stability, but it makes pulling hills easier.","replyToPid":0}
发表于 2019-9-14 03:21:41 来自手机 | 显示全部楼层
87881 发表于 2019-09-13 13:56:17 Not necessarily true. Lose traction on the tandem with little weight means that trailer is coming to meet you up close and personal. Even distribution of weight not only provides more stability, but it makes pulling hills easier.
","text":"Sorry peb’s but that is incorrect ","replyToPid":207143}
发表于 2019-9-17 02:12:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"No need to apologize. I’m basing my response here on personal experience. We’re all different and this has always been true for me. We all handle the road differently and have our own preferences and what works for us. ","replyToPid":0}
发表于 2019-9-17 10:51:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"The driver telling you to have more weight on your drives is a imbicile. You want to have more weight on all axles during the winter. You especially want your trl tandems to have the extra weight. Makes them stick better. The less weight you have on them the more likely the tandem is going to skid. If you find yourself with your trl trying to slide around on you, pull your trl brake handle and give it fuel. Do not use your engine brakes during icy travel unless you can do this.","replyToPid":0}
GMT+8, 2026-4-18 07:01 , Processed in 0.083357 second(s), 24 queries .
