查看: 123|回复: 3
Games other truckers play
 楼主| 发表于 2019-9-2 08:31:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"You can count on an ungoverned truck to pass you aggressively and get in front of you. Once in front of you they set cruise to slower than your speed. You attempt to pass only to find out they have sped up and won’t allow you to pass them and they cause a traffic back up with you in the left lane looking like the villain. Other trucks will hate you and drive aggressively around you and brake check you. Don’t fall for this.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-13 21:54:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not governed and have never done these things, ever. In fact, in 22 years running I’ve yet to see a governed truck do this. What I have witnessed more times than I can recall are 65mph governed trucks blocking the fast lane-TX I35 constantly. If you can’t drive the actual speed limit keep to the right. If you see a faster truck approaching and the right is clear, move to the right and stay there. ","replyToPid":0}
发表于 2019-9-3 04:24:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"You appear to have an issue with “ungoverned trucks”","replyToPid":0}
 楼主| 发表于 2019-9-2 08:33:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Very common to see this around Chicago.","replyToPid":0}
GMT+8, 2026-4-18 04:28 , Processed in 0.074969 second(s), 24 queries .
