查看: 88|回复: 1
Traps
 楼主| 发表于 2019-9-2 08:10:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"There are several drivers that fully intend on striking your truck with their trailer at different locations. Where construction has 2 lanes separated that come together for a short period of time there will be a truck not governed at 65 that will speed up and hit you when the lanes come together and speed away, Hischbach lease operator did this to me.\nOn the New Jersey Turnpike the will be a National Freight Inc. daycab that will try and pass you in the right lane that is ending, he will be able to pass you and he is ungoverned, he will proceed to run his trailer into your mirror.\nGoing through Atlanta at night there will be a Black Pete and his JB Hunt friend that will take turns getting in front of you and break checking you and they will pursue you and continue to take turns slowing in front of you and high beam lighting your mirrors.\nOn I-80 westbound there will be a former Harley truck and trailer that will pull out from the weigh station at 35 mph and you should stay in the right lane and don’t try to go around because you will miss your exit if you do.\nExpect every truck to try and run their trailer into your truck as they pass you and might as well drive 5mph slower than the speed limit to avoid getting hit and allow them to pass you faster.\nIf you are governed at 65 expect every vehicle to pass you and do something stupid in front of you.\nYou can expect other drivers to show no courtesy including other truck drivers. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-13 21:57:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like you’re an aggressive driver and an unsafe driver all around based on your posts. ","replyToPid":0}
GMT+8, 2026-4-18 02:50 , Processed in 0.070419 second(s), 23 queries .
