查看: 444|回复: 30
Worst truck stop you have ever been into?
 楼主| 发表于 2019-9-2 05:53:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"Drums, PA Pilot.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-2 21:46:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Petro Atlanta","replyToPid":0}
发表于 2019-9-2 09:51:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can count on no cold water and scalding hot boiler water at Flying J because the employees are turning the valve for the cold water off.","replyToPid":0}
发表于 2019-9-3 02:45:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any truck stop with truck drivers is a bad truck stop.","replyToPid":0}
发表于 2019-9-2 10:02:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Flying J from Milton PA comes to mind. The parking lot is filled with holes and last time I stopped there the bathroom and the restaurant smelled really bad. Also the Flying J from Breezewood, PA...  ","replyToPid":0}
发表于 2019-9-2 16:23:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sweet Pea's in Wheatley, Ar.","replyToPid":0}
发表于 2019-9-2 11:05:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Worst ones I’ve been to recently are both PFJ in Troutville, VA and Kansas City, KS","replyToPid":0}
发表于 2019-9-2 10:42:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"The AC in the showers of pilots does not work but they have the heat on in Aug to dry the floor.","replyToPid":0}
发表于 2019-9-2 10:34:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Loves, in troutdale Oregon by far 😂","replyToPid":0}
发表于 2019-9-3 20:25:51 来自手机 | 显示全部楼层
646003 发表于 2019-09-02 18:49:44 My bad I meant the TA, I don’t think I’ve ever been around a loves there.
","text":"The TA isn’t bad at all, but the Love’s next door is garbage 😂","replyToPid":199790}
发表于 2019-9-3 06:15:28 来自手机 | 显示全部楼层
623679 发表于 2019-09-02 02:34:21 Loves, in troutdale Oregon by far 😂
","text":"I agree. The last time I was there, I saw used syringes in the parking lot. ","replyToPid":199335}
发表于 2019-9-2 11:21:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Probably the circle k in Phoenix if it’s still around there just a lot of hustling go around there. ","replyToPid":0}
发表于 2019-9-3 01:50:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Worst place I've been to was this little hole in the wall run down gas station north of Philly. $15 to park for the night, only place nearby to park so they got away with it, no restroom, just a porta-can outside, gravel lot with lots of pot holes, and nowhere nearby to eat.\n\nIf I'd had literally anywhere else to go, I'd have gone there. Hands down, worst place I've been to.","replyToPid":0}
GMT+8, 2026-2-10 11:41 , Processed in 0.118602 second(s), 24 queries .
