查看: 42|回复: 1
2006, 387 gauge problem.
 楼主| 发表于 2019-1-24 18:05:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"I`ve got a 2006, 387 with a full gauge package. Whats happening is that the front and back rear temp gaugs as well as the tranny temp and fuel gauges go crazy all at once and the needles creep up to the point that all the safety bells and whistles go off. If I turn the key off and back on real fast they will reset. Sometimes stay normal for miles sometimes not. I want to get this fixed because its a real pain in the ass. Dosen`t affect the running of the truck but the foot { clutch } pedal no longer shuts the jake off nor will it cancel out the cruise.","pics":"[]","canComment":true}
发表于 2019-3-4 10:51:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can't give you advice, because there could be 100 different causes making it do that. Just want to give you a positive response! Be thankful it older than a 2007!!! You have that going for you 👌","replyToPid":0}
GMT+8, 2026-4-17 08:04 , Processed in 0.072670 second(s), 23 queries .
