查看: 196|回复: 7
Cpap
 楼主| 发表于 2019-9-1 19:38:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Beavis how like useing your cpap machine ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":433.0,\"name\":\"\",\"url\":\"\",\"width\":308.0}]","canComment":true}
发表于 2019-9-2 07:51:39 来自手机 | 显示全部楼层
{"replyTo":"","text":" lose some\nWeight and you might not need that contraption. ","replyToPid":0}
发表于 2019-9-2 05:16:10 来自手机 | 显示全部楼层
643146 发表于 2019-09-01 21:12:58 Is that a vacuum cleaner?
","text":"I bet it is. LOL","replyToPid":199038}
发表于 2019-9-4 07:08:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"ya don't have to b a little chunky to have to use one of these.. if you snore the you will be required to wear one.  and yes this old fat ugly woman wears one every night and I sleep great","replyToPid":0}
发表于 2019-9-4 12:53:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't have to be on the heavy side to have to use this. if you snore. then you u are qualified to use the C-PAP","replyToPid":0}
发表于 2019-9-2 05:12:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is that a vacuum cleaner?","replyToPid":0}
发表于 2019-9-10 23:22:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lmao I struck a soft spot with fat America ","replyToPid":0}
发表于 2019-9-10 23:24:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Lmao \nIn adults, the most common cause of obstructive sleep apnea is excess weight and obesity, which is associated with soft tissue of the mouth and throat. Put down the fork and quit making excuses. "}
GMT+8, 2026-4-18 02:31 , Processed in 0.104554 second(s), 24 queries .
