查看: 73|回复: 0
TriPac APU Alarm Codes
 楼主| 发表于 2019-1-24 18:05:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I looked all over the internet for a TriPac APU Manual and the Alarm Codes but I did some 2 Hours of looking for my manual and it was under my bed in the Cab (Which contains all Alarm codes on page 30). \n\nFor all those having problems with there Tripac APU then here is all the Alarm Codes for it!\n\nTriPac HMI Controller alarm codes are:\n\nEnG: This code indicates that the \"8\" circuit has a failure. This can be caused by an open engine reset switch (resulting from low oil pressure or high water temperature) or the Main Power On/Off Switch is in the off position.\n\nALSO\nthis 1 is also common if there is air in the coolant lines, if you recently had the trucks coolant drained for any reason and the apu was not bled of air, then it will throw this code also\n\nAcS: This code indicates that an abnormal air conditioning system condition has occured. Typical cause are high discharge pressure or low pressure. (In my own words your APU needs Freon)\n\nALt: This code indicates that a charging system failure has occurred. This code will occur if there is no alternator output after 2 minutes of operation.\n\nTo clear Alarm Codes, use the HMI Main Power Key to turn off the TriPac system.\n\n\n\n\nThis is straight from the Manual and these are ALL the codes (except the \"In my own words\" part). A lot of people are trying to find these codes so here they are! Any questions just ask!","pics":"[]","canComment":true}
GMT+8, 2026-3-21 18:37 , Processed in 0.058543 second(s), 23 queries .
