查看: 154|回复: 6
Does anybody else ever think about your steering components and really understand that those couple of cotter pins
 楼主| 发表于 2019-8-31 03:31:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"are the only things really holding it together?\n\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-1 06:40:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"The cotter pin is only a “lock”so the castle nut doesn’t back off. If the nut was torqued to spec the cotter pin does nothing.","replyToPid":0}
发表于 2019-8-31 05:20:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yèp. Ī chèck thèm în thè møuntains prètty thorøughly. Nutś bôlt cøtter kèy wirè clïps wīre tiès càstle nüts. Pûll pûsh tûg snàtch yànk twíst. Trûck øff twíst thè stèéring whèél.  ","replyToPid":0}
发表于 2019-8-31 05:15:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep. I check them in the mountains pretty thoroughly. Nuts bolt cotter key wire clips wire tires castle nuts. Pull push tug snatch yank twist. Truck off twist the steering wheel ","replyToPid":0}
发表于 2019-8-31 05:17:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep. I check them in the mountains pretty thoroughly. Nutś bôlt kotter key wire clips wire ties castle nüts. Pull pûsh tûg snatch yànk twíst. Truck øff twist the steering wheel ","replyToPid":0}
发表于 2019-8-31 06:23:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"the new BMW car... the steering wheel isnt even connected to the tires through mechanical components you turn the wheel left and a sensor tells the computer what you did and the computer turns  the tires for you....  now... what would happen if you were  to blow a fuse","replyToPid":0}
发表于 2019-9-1 06:39:38 来自手机 | 显示全部楼层
750595 发表于 2019-08-30 22:23:37 the new BMW car... the steering wheel isnt even connected to the tires through mechanical components you turn the wheel left and a sensor tells the computer what you did and the computer turns  the tires for you....  now... what would happen if you were  to blow a fuse
","text":"The cotter pin is only a “lock”so the castle nut doesn’t back off. If the nut was torqued to spec the cotter pin does nothing.","replyToPid":197720}
GMT+8, 2026-4-18 07:02 , Processed in 0.066950 second(s), 24 queries .
