查看: 196|回复: 6
i need to figure out this 8 2 split thing ..
 楼主| 发表于 2019-8-31 00:58:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"ok i am going to run outa time here in mass i need six hours plus to get back to ny.. i have been on off duty for a lil over two hours and can be parked for my 8 hour about five mins down the road how do i tell how much time ill get back ... please help","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-8-31 02:04:15 来自手机 | 显示全部楼层
679939 发表于 2019-08-30 17:54:51 I use split break all the time. This is the way it works, go to sleeper for 8hrs and get the  your driving hours you didn't use and before those hours run out, take a 2 hour break and get the rest of your hours back. Hope my explanation helps
","text":"es it des thank u very much","replyToPid":197436}
发表于 2019-8-31 01:54:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use split break all the time. This is the way it works, go to sleeper for 8hrs and get the  your driving hours you didn't use and before those hours run out, take a 2 hour break and get the rest of your hours back. Hope my explanation helps","replyToPid":0}
发表于 2019-8-31 09:45:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"First you must have 8 on SB to start a split-technically DOT doesn’t care if it’s off duty or SB, but the elog DOES. That 8 hours pauses the 14. You then get the remaining hours on your 11/14. Let me give you an example:\nOn duty 0600 PTI\nDriving 0615-12:15 (6 hours 15 minutes used up on the 14 leaving 7:45/14 available)\nSB 12:15-20:15 (8 hours to pause the 14)\nIn this example I’d have 7:45 left on my 14, and 5 hours of driving time.\n20:15-20:30 PTI \n20:30- 01:15 driving \n01:15-01:20 Post trip\n01:20 -03:30 SB (I’ve now completed my split, BUT I only have the original time I drove available to me until I take my full 10) \nHours available are now 6 hours driving time and 8 on my 14. \nYou continue to roll the time this way until you take a full 10 hour break at which time you regain the full 11/14 again. Hope that helps clarify ","replyToPid":0}
发表于 2019-8-31 05:35:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"make sure those 2 hours are in the sleeper","replyToPid":0}
发表于 2019-8-31 13:57:21 来自手机 | 显示全部楼层
639913 发表于 2019-08-30 21:35:02 make sure those 2 hours are in the sleeper
","text":"either in the sleeper or it can be off duty","replyToPid":197642}
发表于 2019-8-31 01:23:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"think you get on duty time back only I run paper so honestly not sure","replyToPid":0}
GMT+8, 2026-4-18 06:36 , Processed in 0.123964 second(s), 24 queries .
