查看: 285|回复: 11
WiFi for trucks
 楼主| 发表于 2019-8-30 02:35:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"I saw that a lot of people use the Verizon jet pack so I went to look into it and they said it only comes with 15 gigs of data I would go through that in a few days .. what are other options for WiFi in trucks? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-30 08:59:15 来自手机 | 显示全部楼层
{"replyTo":"","text":" Stop watching p.orn","replyToPid":0}
回复 支持 1 反对 3
发表于 2019-8-30 13:56:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go on Ebay and type in unlimited data hotspot. its $39.99 now. all you need is a hotspot device which you can also buy from EBay for 49 bucks. I have one works perfect I've gone through 108gigs already still have 17 days to go😀","replyToPid":0}
发表于 2019-8-30 07:39:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"also wondering the same","replyToPid":0}
发表于 2019-8-30 08:41:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I am using the jetpack...run into data problems after a couple of weeks. Netflix and hulu run fine, but forget vudu and amazon prime","replyToPid":0}
发表于 2019-8-31 05:57:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got unlimited never use WiFi no problems.\nUse Pluto Tv to watch tv if I don’t like what’s in Direct tv.","replyToPid":0}
发表于 2019-8-30 11:13:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pay for the above unlimited plan and never have any data issues. Comes with hotspot for your other devices. Check it out. ","replyToPid":0}
发表于 2019-8-30 09:41:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use sprint with an iPad w unlimited service for an extra $35 a month ","replyToPid":0}
 楼主| 发表于 2019-8-31 21:59:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks everyone for your help!!!!","replyToPid":0}
发表于 2019-8-31 12:24:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Home router with Netbuddy","replyToPid":0}
发表于 2019-8-31 23:14:47 来自手机 | 显示全部楼层
743704 发表于 2019-08-31 13:59:02 Thanks everyone for your help!!!!
","text":"👍","replyToPid":198085}
GMT+8, 2026-4-18 07:01 , Processed in 0.107336 second(s), 24 queries .
