查看: 360|回复: 15
gps navigation system???
 楼主| 发表于 2019-8-29 00:09:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm a new driver, just got my CDL. Is there any trucking gps system that anyone would recommend buying.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-30 11:08:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rand McNally Truckers Atlas!\nit'll never do any of the following...\nloose power,\nstop charging,\nloose signal,\nfail to operate without a 12v supply, \nfail to operate when wet,\nfail to operate due to sun damage,\nfail to operate due to extreme heat or cold,\nfall off your mount and break...\n\nAnd so much more!!","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-8-29 02:29:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin trucker gps best there is. ","replyToPid":0}
发表于 2019-9-11 18:38:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"nome, learn to use an atlas, learn how to call for directions. Atleast for a few months. That way you'll can learn by heart how the interstate system works","replyToPid":0}
发表于 2019-9-9 13:39:25 来自手机 | 显示全部楼层
646385 发表于 2019-08-29 14:30:52 I'll be the odd one out and recommend rand mcnally. got mine for $200 and it works just fine
","text":"I'm with you rand mcnally all the way.","replyToPid":196419}
发表于 2019-8-29 10:54:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin Dezl","replyToPid":0}
发表于 2019-8-31 06:19:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a road atlas, no better way to learn","replyToPid":0}
发表于 2019-8-29 21:42:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Definitely Garmin","replyToPid":0}
发表于 2019-8-29 21:45:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin trucker dezl ","replyToPid":0}
发表于 2019-8-29 22:30:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll be the odd one out and recommend rand mcnally. got mine for $200 and it works just fine","replyToPid":0}
发表于 2019-8-30 00:17:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin Dezl is the best. But with any gps you still need to trip plan.","replyToPid":0}
发表于 2019-8-30 00:37:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a rand McNally TND 740 i really like the view of screen and all functionality, but broke down on me cuz I left it on while home time right on the windshield and the heat caused battery damage but it got fix under warranty and it going really good.","replyToPid":0}
 楼主| 发表于 2019-8-30 06:47:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for the recommendations 👍","replyToPid":0}
GMT+8, 2026-4-17 23:07 , Processed in 0.128383 second(s), 24 queries .
