查看: 730|回复: 23
I have no idea what I'm doing
 楼主| 发表于 2019-8-28 04:39:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just bought a Cobra 29lx CB for my 2020 t680 thinking it'd be easy because the truck comes with the antennas and wiring already there... but none of the plugs match the back of this CB except one of them, there are wires hanging from my overhead console and I'm at a loss. can anyone talk me through wth to do 😭","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-28 07:35:59 来自手机 | 显示全部楼层
716994 发表于 2019-08-27 21:32:48 I keep getting an error trying to repost with the pic.
","text":"liar","replyToPid":194176}
发表于 2019-8-28 07:35:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"lair","replyToPid":0}
发表于 2019-8-28 05:17:54 来自手机 | 显示全部楼层
716994 发表于 2019-08-27 21:17:02 yea, the one for the antenna is the only one that matches
","text":"Start a different post with pics of the wires","replyToPid":194148}
发表于 2019-8-28 05:17:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"You also need power.","replyToPid":0}
 楼主| 发表于 2019-8-28 05:17:02 来自手机 | 显示全部楼层
787563 发表于 2019-08-27 20:51:56 The one that matches is the screw on right?
","text":"yea, the one for the antenna is the only one that matches","replyToPid":194068}
发表于 2019-8-28 04:51:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"The one that matches is the screw on right?","replyToPid":0}
 楼主| 发表于 2019-8-28 05:32:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I keep getting an error trying to repost with the pic.","replyToPid":0}
 楼主| 发表于 2019-8-28 05:36:16 来自手机 | 显示全部楼层
787563 发表于 2019-08-27 21:17:54 Start a different post with pics of the wires
","text":"it's not letting me put up pics but I have 4 wires, the thick black one for the antenna, one for my speaker it looks like and there's a black and a red wire with what looks like a screw instead of a plug at the end of the wire at a 90° angle... dunno if  that helps, the tag on it says harness binding posts","replyToPid":194150}
发表于 2019-8-28 06:03:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have to hook your plug for the radio to that red and black wires red to red black to black","replyToPid":0}
发表于 2019-8-28 06:06:59 来自手机 | 显示全部楼层
716994 发表于 2019-08-27 21:36:16 it's not letting me put up pics but I have 4 wires, the thick black one for the antenna, one for my speaker it looks like and there's a black and a red wire with what looks like a screw instead of a plug at the end of the wire at a 90° angle... dunno if  that helps, the tag on it says harness binding posts
","text":"Red wire for power black ground external speaker should have small plug like headphones ","replyToPid":194181}
发表于 2019-8-28 07:28:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"?","replyToPid":0}
GMT+8, 2026-4-16 15:08 , Processed in 0.116210 second(s), 25 queries .
