查看: 546|回复: 32
Driving on snow and ice.
 楼主| 发表于 2019-8-28 04:26:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"I could use a little advice about driving in the snow and ice. Particularly mountain and downgrades.  I've had very minimal training on winter driving.  Just trying to prepare myself before winter starts. Been on my mind a lot lately. I love my job but being from the south it has definitely put a healthy fear in me. I appreciate any advice. Please saves the jokes. Everyone had to start somewhere. Thanks in advance\n ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-28 12:41:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take it easy, go slow until you get out of it, DO NOT USE CRUISE, use 4ways, never set your trailer brakes when parking overnight, drain your air tanks daily, carry rubbing alcohol to put in airlines, buy 10lbs of cat little in case you need traction, keep rpms as low as possible when accelerating, dont fly downhill, Crest over slowly and keep it under control, use stab braking, dont use trolly valve(if you have one), if you can't see others, they can't see you, pull off in a SAFE location, dont park on the shoulders or exit ramps, do everything slowly and deliberately and you'll do just fine.","replyToPid":0}
回复 支持 8 反对 0
发表于 2019-8-28 05:23:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just take it slow. When chain law is up park the truck till it’s gone. ","replyToPid":0}
回复 支持 8 反对 0
发表于 2019-8-28 11:43:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just take your time with it don’t rush, if you’re not comfortable don’t do it never use your chains to get into a situation only to get out of one. Stay calm especially on down grades in the snow don’t do anything jerky. Also try not to overthink it. Add Checking the weather forecast and road conditions regularly to your trip plan. Keep a small tub or bucket of salt/sand. Don’t set your trailer breaks unless dropping the trailer. Keep your windshield wiper fluid full. Keep a bottle of rubbing alcohol on you to pour into air lines. I could go on all night with tips and tricks I’ve learned either the hard way or from others mistakes. ","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-8-28 12:36:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s a dumb question! Very dumb! It’s like how do i f my girl type of question!","replyToPid":0}
回复 支持 2 反对 5
发表于 2019-8-28 17:50:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"f- the four way flasher thing ! jeez ! if your too scared dont run: the four way flasher thing then the cars copy the trucks thinking that truckers are the way to follow cause in the olden days THEY WHERE ; the flasher thing just blinds everyone and makes everyone slow down even more! dont drive on the snow and ice if your scared of it period ! some of the advice was pretty decent ! biggest problem isnt you! the proplem is the idiots around you ! either they are going too way slow cause they are scared ; OR. too way fast causs they are cocky! in the olden days i remember riding in a convoy theough horrible storms and everyone using team work! the overall driving atmosphere has made driving in winter way more dangerous than it needs to be! all the advancment in technoloyy and cars ruined by freaks that dont know how to use team work and everyone truck along at a pace 40-50 miles per hour is a nice decent pace to truck it through the worst storm even blinding snow; if you trust the vehicle in front of you and beside you; which i dont anymore","replyToPid":0}
发表于 2019-8-28 11:51:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Take it slow and easy don’t rush yourself no matter what. Don’t jerk the wheel always make smooth adjustments never use chains to get into a situation only to get out of one. Never set trailer breaks unless you’re dropping the trailer. Keep a bottle of rubbing alcohol to pour into airlines. Keep a container of salt/sand mix. If you’re uncomfortable with driving then don’t. Keep your windshield wiper fluid full and carry spare bottles "}
 楼主| 发表于 2019-9-17 06:01:55 来自手机 | 显示全部楼层
87881 发表于 2019-09-13 14:24:47 I agree with the actual advice given above but here’s a couple more not mentioned yet...\nCarry a small shovel and cat litter in case you get stuck in a slippery spot-or in a dock that hasn’t been deiced. \nAlways keep MREs or other non perishable food on your truck. If you run 80 through Wyoming they shutdown the freeway when it gets bad and if you’re in a rest/parking area you might be there a couple days before it reopens. \nKeep extra blankets and warm clothes on the truck in the event you breakdown and have no heat.\nDO NOT let dispatch drive your rig. If it’s not safe, park it. Brokers, shippers and receivers ALL make accommodations for rescheduling during winter months. If dispatch tries to pressure you into driving during a bad storm because “it’s a hot load” or “has to be on time” your reply should be “it can get there late but intact, or they can salvage it roadside from an accident.” Watch how quickly they change their tune. \nIf you’re not comfortable going at least 45mph find somewhere to park it till conditions improve.\nI’m from the south and experienced the same intense anxiety my first couple winters out here. Something that worked well for me to psych myself up to keep going until I got more comfortable driving in winter was telling myself “if it doesn’t get better in 5 miles im parking.” Usually it would ease up a bit in the 5 miles and I could keep going. Now unless it’s a skating rink or extremely heavy snowfall I just roll with it. I also watch the weather like a hawk! If I can reroute and avoid the storm, I do. Some companies don’t let you deviate from the routing, so ask dispatch if it’s possible or call them and request a different route to avoid most or all of the big storms. \nIf you start sliding DONT panic. SMALL adjustments only! \nWith roads that aren’t cleared/icy, find the rumble strip and keep the right tires on it. You’ll have traction with the rumble strip to get to the next parking area safely. \nDrop an extra gear at the top of a grade and keep jakes on low/medium (medium if you have 3-stages)\nYou might have to chain to get out of a dock if it’s icy/snow packed and this is where the kitty litter helps tremendously! Before ya back in the dock sprinkle a little bit where your drives will be sitting to get a bit more traction to get out.\nWhen you back into a spot: pull up a couple times to cool the tires and prevent the pavement from icing up from melting with hot tires.\nNEVER set trailer brakes in the winter unless you’re dropping it. \nIf brakes freeze to the drums use a flathead screwdriver and mallet to separate them.\nALWAYS watch the mirrors to confirm ALL tires are rolling when leaving your spot.\nCarry either rubbing alcohol or brake antifreeze and Diesel 911 plus use Howe’s or another antigel for fuel system.
","text":"Hey pebbles. Thank you so much. I actually saved your comment to my phone. Lots of good tips. Ty.","replyToPid":207190}
发表于 2019-8-29 00:57:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Work for a company like I do that says of you need chains then park it.  No load is worth your life.","replyToPid":0}
发表于 2019-9-17 11:04:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also NEVER EVER USE YOUR CRUISE. .","replyToPid":0}
发表于 2019-9-14 00:35:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks for the question man. I'm from louisiana myself and I have the same concerns. the advice these guys gave is awesome.","replyToPid":0}
发表于 2019-8-28 12:28:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just take your time and make sure your jake brake is set to medium don’t get in to big of a rush the last thing you want is 63 ft of tractor trailer, weighing some tons slipping and sliding out of control, \n\nKeep it under 60 and refrain from sudden movements of the wheel. \n\nSet your cruise if need be but remember take your time, stay safe, and keep the rubber on the road. ","replyToPid":0}
发表于 2019-8-28 12:31:52 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"What they said👇. Should have been in your dmv book. "}
 楼主| 发表于 2019-8-28 13:57:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for all the advice. I appreciate it. I definitely learned a few things I didn't know. Stay safe.","replyToPid":0}
 楼主| 发表于 2019-8-28 13:58:30 来自手机 | 显示全部楼层
83379 发表于 2019-08-28 04:36:24 That’s a dumb question! Very dumb! It’s like how do i f my girl type of question!
","text":"There's always one. Be safe out there man.","replyToPid":194690}
GMT+8, 2026-4-18 02:32 , Processed in 0.156372 second(s), 24 queries .
