查看: 154|回复: 4
what to do when a tire explodes on the road? steps, whom should I call if my dispatcher does not answer my calls.
 楼主| 发表于 2019-8-27 07:17:35 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-8-27 08:00:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Call roadside ASAP. Then call your dispatch. Your safety is number one ","replyToPid":0}
发表于 2019-8-27 09:59:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ghostbusters!!!","replyToPid":0}
发表于 2019-8-27 07:19:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Call road rescue ","replyToPid":0}
发表于 2019-8-28 10:38:26 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"First off assess the situation if you’re in a safe area or safe as possible area set up your triangles. If you’re not in a safe area slowly move to a safer area. Then the triangles. Then call road repairs. Then call your dispatcher cause then you can tell him/or her the problem, the solution, and a estimated time frame of the delay. All of which you should get from your road side people/person. "}
GMT+8, 2026-4-18 07:02 , Processed in 0.085833 second(s), 24 queries .
