查看: 183|回复: 9
zip to zip is there a minimum standard to this issue i get in a truck with 15k get with 43k but only got paid 3300.00
 楼主| 发表于 2019-8-26 21:04:21 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-8-27 06:57:00 来自手机 | 显示全部楼层
发表于 2019-8-26 22:46:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could you ask that again?","replyToPid":0}
发表于 2019-8-26 23:17:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ya that you must mean 2,800   not 28k","replyToPid":0}
 楼主| 发表于 2019-8-26 23:06:04 来自手机 | 显示全部楼层
723808 发表于 2019-08-26 14:46:10 Could you ask that again?
","text":"if i do 28k but dont get paid for it at .32 mile because of the zip to zip system is there a minimum standard that companies should be limited to","replyToPid":192454}
 楼主| 发表于 2019-8-26 23:09:40 来自手机 | 显示全部楼层
524069 发表于 2019-08-26 15:06:04 if i do 28k but dont get paid for it at .32 mile because of the zip to zip system is there a minimum standard that companies should be limited to
","text":"i only got 3300.00","replyToPid":192479}
 楼主| 发表于 2019-8-27 17:51:59 来自手机 | 显示全部楼层
505487 发表于 2019-08-26 15:17:57 Ya that you must mean 2,800   not 28k
","text":"no dude 43 k minus 15k is not 2800","replyToPid":192488}
发表于 2019-8-28 11:02:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok so if I get this straight. you are asking why you ran 28K miles at .32cpm you only received  $3,300 instead of the instead of the full $8,960 for the actual miles run. By running zip to zip they shorted you like 10k miles or $5,380\n\nLet me know If I got that deciphered correctly ","replyToPid":0}
发表于 2019-8-28 11:05:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok so if I get this straight. you are asking why you ran 28K miles at .32cpm you only received  $3,300 instead of the instead of the full $8,960 for the actual miles run. By running zip to zip they shorted you like 10k miles or $5,380\n\nLet me know If I got that deciphered correctly.  \n\nNot that I know of on the minimum standard but .32cpm is somewhere at the bottom of company pay to begin with ","replyToPid":0}
发表于 2019-8-28 11:06:38 来自手机 | 显示全部楼层
","text":"Lol that’s not much better ","replyToPid":192479}
GMT+8, 2026-4-18 07:01 , Processed in 0.086331 second(s), 24 queries .
