查看: 269|回复: 12
Question regarding transport trucks and flashing their lights at you
 楼主| 发表于 2019-8-25 01:38:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"So, my pal is travelling across Canada in a U-haul with a girlfriend and two dogs and have noticed that within the last two provinces (Quebec and New Brunswick) almost every transport truck they have passed has flashed their lights at them. \n\nThe first couple of times he thought that something was wrong so he pulled over and checked lights, tires, etc, but nothing was wrong with the truck. \n\nIs this a friendly \"you can move into this lane\" thing or are they're doing something wrong in an unwritten \"rules of the road\" code?\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-25 02:03:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you just passed a truck... and that truck flashes their lights, generally speaking it’s an indication you are safe to return to the traveling lane, with enough space in front of the truck.","replyToPid":0}
发表于 2019-8-27 05:39:41 来自手机 | 显示全部楼层
709004 发表于 2019-08-25 01:03:09 Mama Bear, are you the same Mama Bear that writes messages on rocks and leaves them at fuel islands? lol if so I found one in Texas
","text":"no youngster that's not me . my friends gave me that name when I turned 60. only got 3 friends. oversize Hauler, grain hauler and a pig hauler.","replyToPid":190730}
发表于 2019-8-27 05:41:30 来自手机 | 显示全部楼层
281789 发表于 2019-08-26 21:39:41 no youngster that's not me . my friends gave me that name when I turned 60. only got 3 friends. oversize Hauler, grain hauler and a pig hauler.
","text":"Lol ok thanks for the response ma'am.","replyToPid":192902}
发表于 2019-8-25 04:19:47 来自手机 | 显示全部楼层
310244 发表于 2019-08-24 18:03:56 If you just passed a truck... and that truck flashes their lights, generally speaking it’s an indication you are safe to return to the traveling lane, with enough space in front of the truck.
","text":"or could be alerting you that cops are right around the corner so be aware","replyToPid":190360}
发表于 2019-8-25 04:41:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you pass the transport vehicle it means you are clear.  if you are traveling the other direction it mean there is an QPP , OPP or RCMP up ahead. the Transport Drivers in Quebec and the Maritime are more likely to help you out if you have questions or need anything","replyToPid":0}
发表于 2019-8-25 09:03:09 来自手机 | 显示全部楼层
281789 发表于 2019-08-24 20:41:43 if you pass the transport vehicle it means you are clear.  if you are traveling the other direction it mean there is an QPP , OPP or RCMP up ahead. the Transport Drivers in Quebec and the Maritime are more likely to help you out if you have questions or need anything
","text":"Mama Bear, are you the same Mama Bear that writes messages on rocks and leaves them at fuel islands? lol if so I found one in Texas","replyToPid":190540}
发表于 2019-8-25 10:08:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"fake TP account","replyToPid":0}
发表于 2019-8-25 22:21:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"flip them off 🖕","replyToPid":0}
发表于 2019-8-27 05:41:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"you youngster are a man that likes to stir the caldron and see what happens. hehehe","replyToPid":191153}
GMT+8, 2026-4-18 07:01 , Processed in 0.081160 second(s), 24 queries .
