查看: 234|回复: 10
How much gasoline can a semi truck's fuel tank carry?
 楼主| 发表于 2019-8-24 06:16:56 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-8-24 11:42:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's diesel, not gasoline; and it can vary from 90% of 50 gallon tank to 150+ per tank, usually 2 tanks per tractor.  The 10% unusable is supposedly for expansion room.","replyToPid":0}
发表于 2019-8-24 21:22:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends on how many gallons the tanks are.","replyToPid":0}
发表于 2019-8-24 23:30:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"200 gallons of Diesel if you have 100 on each side like mine. ","replyToPid":0}
发表于 2019-8-24 23:31:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would imagine the same amount it'll hold in diesel.","replyToPid":0}
发表于 2019-8-25 00:02:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"All the way to the top","replyToPid":0}
发表于 2019-8-25 09:53:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I heard some old guys saying something one time about mixing a gallon of gas to each tank of diesel to help clean injectors out. But much more would burn cylinders out probably!","replyToPid":0}
发表于 2019-8-25 10:11:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤣🤣🤣🤣","replyToPid":0}
发表于 2019-8-25 10:15:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's like asking how much washer fluid does it hold.... it dont really matter... unless you are trying to configure your weight... which 1 gallon of diesel  is 6.93 lbs","replyToPid":0}
发表于 2019-8-25 12:06:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"As much as the tanks hold,but it won’t run very long.","replyToPid":0}
GMT+8, 2026-4-18 08:51 , Processed in 0.070687 second(s), 24 queries .
