查看: 393|回复: 17
Oil change
 楼主| 发表于 2019-5-19 07:53:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"After oil change my truck is having a hard time to start up? Who knows what happened?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-19 08:26:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Didn't get fuel filters primed like they should have","replyToPid":0}
发表于 2019-5-19 08:08:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air in fuel line if you got a full pm service done ","replyToPid":0}
发表于 2019-5-19 11:22:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to prime your fuel system.  You can cycle your gauges 4 or 5 times. Turn your key to start but dont try to start. Let your annunciator light up and let the gauges cycle. Your fuel is being primed electrically while your gauges cycle. If you have to much air in the fuel lines you'll have to manually prime your fuel system. You have to use the pump on the fuel pump. Pump the fuel til you feel resistance and try to start your truck.","replyToPid":0}
 楼主| 发表于 2019-5-19 09:35:22 来自手机 | 显示全部楼层
664145 发表于 2019-05-19 00:25:13 Go back 2 da place & have them look & fix it
","text":"I just got back here they have to fix what they broke or did","replyToPid":37824}
发表于 2019-5-19 08:18:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"just an oil change wouldn't have affected ur fuel system quit taking ur truck to ta wait till u tryto take ur filters off i hsd to use a 3 foot pipe wrench","replyToPid":0}
发表于 2019-5-19 08:25:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go back 2 da place & have them look & fix it","replyToPid":0}
发表于 2019-5-20 05:01:21 来自手机 | 显示全部楼层
664145 发表于 2019-05-19 20:54:29 Letting a place job U ova enables perpetuating bad customer service.
","text":"you are right but if people would wise up and stop using them wouldn't have a business anymore to screw people","replyToPid":38184}
发表于 2019-5-20 05:20:04 来自手机 | 显示全部楼层
{"replyToPid":38201,"replyTo":"
596577 发表于 2019-05-19 21:01:21 you are right but if people would wise up and stop using them wouldn't have a business anymore to screw people
","text":"If it's yo 1st visit thurr,\nletting 'em off da hook scott free shows they ripped U off."}
 楼主| 发表于 2019-5-19 09:34:12 来自手机 | 显示全部楼层
330127 发表于 2019-05-19 00:08:02 Air in fuel line if you got a full pm service done
","text":"I couldn’t turn on the truck for several minutes after 8 hours sleep ","replyToPid":37818}
 楼主| 发表于 2019-5-19 09:34:32 来自手机 | 显示全部楼层
596577 发表于 2019-05-19 00:18:22 just an oil change wouldn't have affected ur fuel system quit taking ur truck to ta wait till u tryto take ur filters off i hsd to use a 3 foot pipe wrench
","text":"Thx","replyToPid":37822}
发表于 2019-5-19 10:22:57 来自手机 | 显示全部楼层
","text":"yea cuz they did such a good job last time","replyToPid":37824}
GMT+8, 2026-4-16 22:17 , Processed in 0.097106 second(s), 24 queries .
