查看: 176|回复: 8
tight dispatch times
 楼主| 发表于 2019-8-23 03:46:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm getting frustrated with my dispatch. They dispatch craziness to me, tell me they cant adjust the times and have general discontent with the garbage they are spitting out at me like I did this abuse to myself. Yesterday I got a load dispatched with a DDT of 3 hours after the delivery time. It was drop and hook with a window so I was a little bit on the late side. I asked for more time and was told I didn't give them enough time to address the issue. But it was only a 3 hour run.....so I am clueless how I can create time from that mess. Today, I was dispatched an hour before I needed to be 50 miles away in Chicago morning traffic. so I had to rush in without fueling or trailer washout. how do I put an end to this abuse? she complains regularly to everyone so I assume it's a bigger problem than me. Do I reject loads? Do I suggest a union or something? it's totally impossible right now to get things done right. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-23 04:43:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"what arakos said.  you just need to learn how to manage your next time available.  give yourself a cushion and shave an hour off your day as an additional cushion.","replyToPid":0}
发表于 2019-8-23 03:52:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Set your ready time. Some companies call it pta (projected time available). \n\nBasically it’s letting dispatcher know when you will be ready after that delivery. ","replyToPid":0}
发表于 2019-11-26 15:09:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"A driver is the most important commodity in the trucking industry. Every load moves by truck unless there’s a railroad at the loading dock. You call the shots in your career. Any company is lucky to have you and should treat you like gold and pay you well. Stop working yourself to death for someone else to profit. Some companies start you at 80k a year and get you home regularly (Walmart) with benefits. I’d suggest keeping ones options open! Don’t stress, look for greener pastures, they won’t look for you.","replyToPid":0}
发表于 2019-8-23 22:43:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"hahahahahahahahahhahaha yep, dont use your brain in anyway !  just bounce from job to job ! GREAT ADVICE! ! be quiet, do your job , do what your doing and ignore the complaints! they are just venting on you and passing the blame, keep working to the best of your ability and ignore the dispatcher complaints! ! the dispatchers im just guessing are over swamped with work as well! ","replyToPid":0}
发表于 2019-8-23 20:27:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"trip plan at 55 mph and give conservative eta/pta. she request preplans when you pick up a load so you can trip plan","replyToPid":0}
发表于 2019-8-23 21:23:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it's that bad find another company... Simple","replyToPid":0}
发表于 2019-8-23 23:44:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I stopped reading at “ it was a drop and hook so I was a little bit late”\n\nWhat made you late do you wake up late, have a break down that ran you late, traffic pile up that made you late. \n\nIf your window don’t  have wiggle room \nMeaning the drop was at 2200 not 2200-2359, then the blame lays at your feet not dispatch most drop and hooks only give you a 30-40 min window so if you are late add a hour on to that and that’s where the problem begins.  Then don’t be like most I see standing around talking, taking there time to drop the trl\nAnd find a empty. You look up and a burn 2 hours doing nothing.  \n\nLate to me\nMeans I just cheated myself out of some money. So\nI’m always on time even early at times, \n\nWe have no control once we get to our destination, but if we on time they have to pay us, if we late that’s a loss to\nUs. \n\n"}
发表于 2019-8-23 23:51:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Wait till you pick up a load on Friday, that don’t deliver till Monday evening and it’s less then 700 miles from point A-B,  you have a full drive clock so you can leave from the origin with 7 hrs of drive time. and everybody gone home for the weekend and weekend dispatch tell you contact your dispatcher on Monday. \n\nYou gone be big mad then. 🤣🤣🤣🤣🤣🤣🤯🤯🤯🤯\n\nYou’ll be begging for those tight dispatch times. "}
GMT+8, 2026-4-19 15:30 , Processed in 0.094386 second(s), 24 queries .
