查看: 208|回复: 2
Speedometer off in brand new 2019 Cascadia
 楼主| 发表于 2019-1-24 17:49:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just got into a new 2019 Cascadia. On the highway, my speedometer shows me going 65 mph but my truck is actually only going 60 mph. I know this is something for freightliner to deal with but I can't get in the shop for a while. Am I missing something. And when I do get it to freightliner, would it be a quick fix?","pics":"[]","canComment":true}
发表于 2019-4-11 01:41:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"i had the same issue twice, they had to change the entire dash display clusters... if they have the parts and are free you should be out in 3days... if not then 3 weeks, 2nd time they had to order parts so i lost almost an entire month of work","replyToPid":0}
发表于 2019-4-18 16:17:58 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"What tires is the truck calibrated too? is where I would start. run off your Gps speed if it is a part until its in never shut down for a noncritical issue like that."}
GMT+8, 2026-4-17 06:23 , Processed in 0.078812 second(s), 23 queries .
