查看: 203|回复: 7
Can you take your 30minute break at the end of your shift?
 楼主| 发表于 2019-8-20 02:11:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"I mean, towards the end of your shift.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-20 04:21:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes you can just drive your 11 and at 10 hours and 30 minutes take your 30 and that will complete you 11 hour drive time. \n\nDon’t worry about taking it in the first 8 hrs rule it doesn’t apply in this time frame that’s from when the had horse pulling hay wagons. ","replyToPid":0}
发表于 2019-8-20 02:13:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"if your shift is less than eight hours lol.  the rule is based on hours...","replyToPid":0}
发表于 2019-8-21 00:55:42 来自手机 | 显示全部楼层
762947 发表于 2019-08-19 20:21:41 Yes you can just drive your 11 and at 10 hours and 30 minutes take your 30 and that will complete you 11 hour drive time. \n\nDon’t worry about taking it in the first 8 hrs rule it doesn’t apply in this time frame that’s from when the had horse pulling hay wagons.
","text":"Bro, you forgot to mention that: you can also take a 30 minute break Before starting your day, so that way you can keep rolling for 11 consecutive hours without any stops.","replyToPid":185411}
发表于 2019-8-20 04:29:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sure at 7&1/2 hours ","replyToPid":0}
发表于 2019-8-20 04:48:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"u have to take the 30 min brake anywhere from the 6th hour up to the 8th hour but u will never get to the 8th hour do to ur 8 mins on duty for pre trip","replyToPid":0}
发表于 2019-8-20 06:58:34 来自手机 | 显示全部楼层
","text":"🤣🤣🤣🤣🤣","replyToPid":185411}
发表于 2019-8-20 16:10:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Or you can save up all your 30 minute breaks for a week and take them all at once  when you get your home time","replyToPid":0}
GMT+8, 2026-4-18 10:42 , Processed in 0.080296 second(s), 24 queries .
