查看: 305|回复: 12
Dilmena
 楼主| 发表于 2019-8-20 01:12:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"Have you guys ever encountered a situation where a place you are sent to is too tight for you to deliver, and if so, what happened next?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true}
发表于 2019-8-20 04:23:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve been in this situation to many times. I pull forward have them get a pallet jack in back I push pallets to edge they pick up with forklift. If loading just reverse situation. ","replyToPid":0}
发表于 2019-8-20 04:37:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"fake tp account","replyToPid":0}
发表于 2019-8-20 07:04:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use lube and force it in order to deliver my big big load","replyToPid":0}
发表于 2019-8-20 03:33:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"dump all your air first...","replyToPid":0}
发表于 2019-8-20 07:09:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"lmao I've been at places where I'm all the way across the road when I'm in the dock.","replyToPid":0}
发表于 2019-8-20 07:12:36 来自手机 | 显示全部楼层
发表于 2019-8-20 11:47:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dront drive local..This is an everyday all day sight..","replyToPid":0}
发表于 2019-8-20 11:48:11 来自手机 | 显示全部楼层
760057 发表于 2019-08-19 23:04:28 I use lube and force it in order to deliver my big big load
","text":"With a name like that, It should have already came with lube!","replyToPid":185637}
发表于 2019-8-21 00:57:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try blind side backing in philly or nyc. ","replyToPid":0}
GMT+8, 2026-4-16 16:29 , Processed in 0.100252 second(s), 24 queries .
